- Apr 29, 2025
- 2025 Tacoma TRD Offroad Long Bed Upgrade Package
Fog Light Buyers Guide for the 4th Gen Tacoma
I’ve been digging into lighting options for the new Tacoma and figured I’d throw together a guide. The stock lights work, but they don’t really shine (pun intended) if you’re out in bad weather or running trails at night. Fog light upgrades give you better function and style to the front of your rig.Fog Lights vs Fang Lights
Fog Lights- Wide, low beam pattern built for cutting through fog, snow, rain, or dust
- Mount in the factory fog pockets
- Pure function and visibility boost
Fang light buyers guide here: https://4gtaco.com/threads/fang-lights-for-4th-gen-tacoma.1285/
- Accent lighting that fills the “fang” slots near the lower grille
- Usually DRL, sequential turn, or amber/white accent modes
- More about style, but they complement fogs really well
AlphaRex DoubleTap Dual Color Fog Lights
Switch between white and amber with a dual projector design.
- Two colors in one kit
- Clean projector look
- Plug-and-play install
Heretic LED Fog Kit
Built tough with a clear lens for max output.
- Clear beam for everyday use
- Rugged sealed housing
- Made specifically for 2024+ Tacoma
Form Lights LED Fog Kit
A solid option with factory-style fitment and good light spread.
- OEM-style mounting
- Bright LED upgrade
- Plug-and-play wiring
Cali Raised LED Fog Replacement Kit
Budget-friendly but a big step up from stock.
- Drop-in replacements
- Bright LED output
- Affordable upgrade
Diode Dynamics SS6 Fog Kit
High-output pods designed to fit the Tacoma’s new fog locations.
- Wide fog beam pattern
- Good optics with cutoff
- Backed by warranty
RIGID Selective Yellow Fog Kit
Premium SAE-compliant fog kit with yellow lenses for better performance in poor weather.
- Direct-fit OEM fog replacement
- Selective yellow beam reduces glare
- Durable IP-rated housing
