ARB OME MT64 1500 Miles Later
drktacoma
2025 DCSB TRD Offroad Underground
I’ve surpassed the 1,500 mile mark since installing the ARB MT64 from Mudify and wanted to give my initial thoughts on how I’ve liked them for those of you who maybe interested in this kit.
For starters, there’s no fancy setup or anything out of the norm, they were taken out of the box and directly bolted on. Installed were the front shock assembly, upper control arms, rear shock, and rear springs. My truck sees a lot of highway miles, light low-speed off-roading, and moderate speed off-roading like fire roads. Check out my installation and initial height breakdown for this kit if you’re interested in seeing that process.
On Road:
Truck rides nicely on the highway! From stock suspension, the MT64 has eliminated brake dive and almost all body roll on the corners. With the digressive valving, they’re on the stiffer side, but in no means are they uncomfortable or harsh. Potholes, small bumps and sudden shock compressions are no problem and the shocks react positively to them. However I’ve noticed with no weight in the bed the rear end is mildly hoppy because of that. If you’ll be running any sort of bed setup or bumper in the rear this shouldn’t be a problem for you at all. This setup needs a little bit of added weight to shine.
I spend a lot of time driving so I wanted something that’d be comfortable and it has received my stamp of approval on that front. Over the last 1500 miles the shocks have broken in and settled just a smidge which I’ve been happy with.
Off Road:
I like to call myself a soft roader or a weekend overlander as the off-roading I do is mostly tame with some light rock crawling. Performance of the shocks on the fire roads both high speed and low speed is great! The high speed scenarios is where the shock valving starts to open up and rip. Comfortable and smooth as the speed rolls into the 35+ zone but just like the on road experience the rear end is a little stiffer without weight than I’d like, but that will change in the near future.
The light rock crawling the truck feels fine, nothing out of the ordinary to note other than the rebound is faster and the I really enjoy having the internal bump stop on the front shocks to catch any sort of bottoming out chances.
MT64s get two big thumbs up for my initial thoughts. As the truck build evolves and modifications get put on I’ll continue to monitor the ride quality and report back, however I suspect no changes in the drivability and comfort this kit offers, if anything the extra weight will help!
