2024+ Tacoma - Manual Transmission & iMT
This thread covers pages 221-223 of your owner's manual, providing comprehensive guidance on operating the manual transmission and Intelligent Manual Transmission (iMT) system in the 2024+ Toyota Tacoma.
Tacoma Manual Transmission: iMT, Shifting & Operation​
Critical requirements to protect your engine and transmission:
  • Do not shift the shift lever to the desired gear without depressing the clutch pedal.
  • Shift the shift lever to R only when the vehicle is stationary.
  • Do not rest your hand on or hold the shift lever any time other than when shifting.
  • In order not to cause the engine to overrev, make sure to only shift gears sequentially.
  • Do not release the clutch pedal suddenly.
iMT System Limitation:
WARNING: iMT is not a system that prevents shift lever operation error or engine overrevving. Depending on the situation, iMT may not operate normally and the shift position may not be changed smoothly. Overly relying on iMT may cause an unexpected accident.
Source: Owner's Manual pages 222-223
Basic Shifting Procedure​
The fundamental 3-step procedure applies to all forward gears and Reverse:
  1. Depress clutch pedal firmly - Push pedal to the floor completely to disengage engine power. This must be a firm, complete press, not partial. iMT will not function properly if clutch is not fully depressed.
  2. Shift to desired gear - Move shift lever to the target gear position. Move one gear at a time sequentially (1 to 2 to 3, not skipping gears). Sequential shifting prevents engine overrevving. Feel for gate resistance as you move lever into position.
  3. Gradually release clutch pedal - Ease foot off pedal to smoothly engage engine power. "Gradually" is critical—sudden release causes transmission shock. For iMT-equipped vehicles, smooth release allows iMT engine speed optimization. Adjust speed of release based on road conditions (smoother on inclines).
Reverse Gear Special Procedure:
If you experience difficulty shifting into Reverse:
1. Shift lever back to Neutral (N)
2. Release the clutch pedal momentarily
3. Re-depress clutch pedal fully
4. Attempt Reverse shift again
Why this helps: Reverse gear synchronizer may need a "reset" if previously engaged at speed. The neutral pause allows synchronizer to settle before re-engagement.
A buzzer will sound to inform you when the shift lever is shifted to the R position.
Source: Owner's Manual pages 221-222
Maximum Speed Limitations by Gear​
These are manufacturer-mandated maximum speeds to prevent engine damage:
Gear2H & 4H Mode (mph / km/h)4L Mode (mph / km/h)
122 (37)8 (14)
245 (73)17 (28)
376 (123)29 (48)
4105 (170)42 (69)
5105 (170)55 (89)
6105 (170)67 (108)
How to read this table:
  • Row = Your current gear (1-6)
  • Left column = Speed limit if in 2H (two-wheel high) OR 4H (four-wheel high)
  • Right column = Speed limit if in 4L (four-wheel low)
  • Exceeding these limits can cause engine damage or transmission failure
Gears 1-3 have significant variation between 2H/4H vs 4L. Gears 4-6 hit approximately 105 mph maximum in 2H/4H but still have low-speed limits in 4L. These limits prevent engine damage during towing or off-road operation.
Source: Owner's Manual page 222
iMT (Intelligent Manual Transmission) System​
What is iMT?
The iMT optimally controls the engine speed to suit the driver's operation of the clutch pedal and shift lever, helping the driver to shift gears more smoothly. Additionally, when the clutch pedal is operated, the iMT helps reduce shift shock, allowing for lighter shift operations when driving on a winding road or incline.
Think of iMT as:
  • Automatic engine speed blipping during downshifts (smoother engagement)
  • Reduced shift shock when accelerating hard or shifting on inclines
  • Support system, NOT replacement for driver skill
  • Technology that enhances smooth shifting, not prevents mistakes
How to Activate iMT:
Press the "iMT" switch. The iMT indicator will illuminate in green. Press the switch again to cancel iMT.
Operation:
  • iMT works automatically when activated
  • You manage clutch and shift lever normally
  • iMT invisibly adjusts engine speed for smoother engagement
  • Disable if you prefer traditional manual feel (optional)
When iMT May Not Operate:
Even with iMT activated, the system cannot work in these situations:
  • The clutch pedal is not fully depressed
  • The clutch pedal is not fully released, such as if a foot is resting on the clutch pedal
  • Shift operation is performed after the vehicle has been coasting with the shift lever in N
  • The shift lever is not operated for a long time after the clutch pedal is depressed
Important: After the shift lever is moved, unless your foot is completely removed from the clutch pedal, the iMT may not operate and the engine speed may not be controlled optimally for the next gear change. To enable the iMT, release the clutch pedal completely and then depress it again before operating the shift lever.
Real-World Tips & Context​
Community Best Practices​
Master the 1st to 2nd Gear Transition Timing
This is the most challenging gear change on the 4th Gen Tacoma manual. The key is precise timing: Shift 1st gear to 3.5-4K RPM, then wait for revs to fall to approximately 2000 RPM before smoothly releasing the clutch. This critical shift requires practice—expect about 5,000 miles of experience to master it smoothly. Rushing this transition causes bucking and jerky engagement.
Source: Tacoma enthusiast forums (Tacoma4G.com, TacomaWorld)
Use iMT for City Driving, Disable for Sport Performance
Use iMT (rev matching) in city driving and light-to-light traffic where the system's automatic rev blipping helps smooth transitions. Switch to Sport mode with iMT disabled when you want traditional manual feel and full driver control. Many experienced drivers prefer manual rev control in Sport mode for more control over engine characteristics.
Source: Tacoma4G.com and TacomaWorld Forums
Normal Mode Delivers Smoother Shifts Than Eco Mode
Use Normal driving mode for manual transmission operation. Eco mode is torque-heavy and makes smooth shifting in lower gears more difficult, especially for newer manual drivers. Eco mode adjusts throttle response and power delivery for fuel economy, making rev matching and smooth clutch engagement more challenging.
Source: Tacoma4G.com Manual Transmission Discussions
Maintain 4WD Components with Regular Use
Drive in four-wheel drive for at least 10 miles each month to ensure front drive components stay lubricated. This circulates lubricant through the front differential, CV axles, and transfer case. Regular 4WD use prevents seal dry-out and component degradation, especially important for manual Tacomas doing off-road work.
Source: 4GTaco.com and TacomaWorld Forums
Don't Apply Early Throttle Before Clutch Engagement
Giving the engine gas before the clutch is engaged causes the engine RPM to spool up independently. When you then release the clutch, this energy forces the drivetrain to absorb the RPM difference abruptly, burning clutch material and causing harsh engagement. This accelerates clutch wear and creates unnecessary stress on transmission synchronizers. Over time, this practice causes premature clutch failure.
Source: Tacoma4G.com and 4GTaco.com Forums
Never Make Sharp Turns in 4WD Mode on Pavement
Sharp turning in 4WD on hard pavement binds the front differential because the inside wheels cannot slip enough to reduce rotational speed. This creates extreme stress on differential components and can cause catastrophic failure of internal gears and bearings. This is an expensive repair and easily preventable.
Source: Multiple Tacoma forums discussing 4WD operation
Don't Over-Rely on iMT to Make You a Better Driver
Believing iMT will prevent mistakes like over-revving or poor clutch control, then driving without proper attention to clutch modulation, creates risk. iMT is a rev-matching system that improves smoothness—it is NOT a fail-safe against driver error. Poor technique with clutch still causes harsh shifts and unnecessary wear.
Source: Tacoma4G.com iMT Discussion Thread
Avoid Impatience with the 1st to 2nd Transition
Trying to shift from 1st to 2nd before revs have dropped sufficiently, or releasing the clutch too quickly when revs are still high, causes bucking and jerky engagement. This puts stress on the transmission synchronizer. The awkward transition is characteristic of this engine's rev hang (an emissions-related throttle behavior, not a defect).
Source: "Smooth Shift Impossible?" Thread - Tacoma4G.com
Understanding Rev Hang​
The 4th Gen Tacoma manual exhibits "rev hang"—the engine RPMs stay elevated longer than traditional manuals when you back off the throttle during downshifting. This is an intentional emissions control strategy, not a defect. It's frustrating initially but becomes manageable with understanding and practice. Rev-hang reduction updates are available through dealer software calibration.
Understanding this as a design choice rather than a malfunction improves owner satisfaction and prevents unnecessary warranty service requests.
Source: Tacoma4G.com "Rev-Hang Reduction" Discussion
iMT System Reality​
Many new owners misunderstand iMT as some form of automatic shifter. iMT (Intelligent Manual Transmission) is specifically an engine rev-matching system: when you downshift and release the clutch, iMT automatically increases engine RPM to match wheel speed, making the engagement smoother. It does NOT shift for you or prevent mistakes. It's a convenience enhancement, not a safety system.
The manual transmission rarity on the 4th Gen Tacoma has created an engaged enthusiast community across TacomaWorld and Tacoma4G.com forums where owners share experiences, techniques, and troubleshooting. New owners benefit significantly from this accumulated knowledge.
Source: Owner Experience Discussions - Tacoma4G.com
Manual Content:
  • Toyota Tacoma 2024+ Owner's Manual (OM04041U), pages 221-223
  • Procedures and specifications verbatim from manufacturer
Community Experience & Tips:
  • TacomaWorld Forum - 4th Generation Tacoma Discussions
  • Tacoma4G.com Forum - 2024+ Tacoma Manual Transmission Threads
  • 4GTaco.com Forum - 4th Gen Tacoma Community
This thread combines official Toyota owner's manual information with verified community experiences. Always verify procedures and specifications in your vehicle's owner's manual. This guide is provided for informational purposes as a consolidation of official manufacturer guidance and community-verified best practices. Follow manufacturer recommendations for all maintenance and operation procedures.
Manual transmission operation varies by driver experience and vehicle condition. If you encounter issues, consult your Toyota dealer or a qualified mechanic specializing in manual transmissions.
