Prinsu Pro Roof Rack for the 4th Gen Tacoma
TacomaForce
www.tacomaforce.com
2024 DCSB TRD Off-Road
4th Gen Tacoma Prinsu Pro Roof Rack_0001_4th gen Prinsu Pro Roof Rack Tacoma Force_0002_Layer 7.jpg
Prinsu Pro Roof Rack for the 4th Gen Tacoma​
If you’re looking to put a roof rack on your 4th Gen Tacoma, take a look at the Prinsu Pro Roof Rack. It’s built specifically for this truck and has quickly become a go-to option.
What You Get with the Prinsu Pro​
  • High-strength custom crossbars
  • Full aluminum construction: strong, lightweight, and corrosion-resistant
  • Integrated wind deflector to cut down noise and add to the aggressive style
  • Drop-in points along every crossbar for easy gear mounting
  • A low-profile design that lines up perfectly with the Tacoma’s roof
Why You’d Want It​
The main reason to consider the Prinsu Pro is its strength. The upgraded crossbars are noticeably more solid than the older style, so if you’re running something heavy like a rooftop tent or gear for longer trips, you won’t get the flex you sometimes see with lighter racks. It also has a ton of mounting options built right in, which saves you from having to drill or modify it just to bolt down lights or recovery boards. Beyond the utility side, it adds a low profile, aggressive, and more trail-ready look without sticking way up or making extra wind noise.
Why We Like It​
From our end, what stands out is how user-friendly the rack is. The install goes smoothly, and the drop-in mounting points make it easy to add or move accessories without tearing the whole thing apart. Once it’s on the truck, it just feels like it belongs there, no rattling, no weird gaps, and it lines up clean with the roofline. We’ve seen plenty of racks that either look bulky or take way too much effort to set up. The Prinsu Pro avoids both of those issues.
Check out the Prinsu Pro at TacomaForce.com: https://www.tacomaforce.com/products/prinsu-pro-roof-rack-4g-tacoma-double-cab
Call/email us anytime to talk with the experts
We offer FREE build consultations!!
(916)-805-6432
info@tacomaforce.com
4th Gen Tacoma Prinsu Pro Roof Rack_0002_4th gen Prinsu Pro Roof Rack Tacoma Force_0001_Layer 8.jpg
Prinsu Pro Roof Rack for the 4th Gen Tacoma If...
First 4th gen snorkel I've seen aftermarket.
I'm not someone who does a lot of 3D printing...
On a level, how much MPG do you guys losing on...
Has anyone removed the inside tailgate panel...
If you didn't know, when you lift the rear end...
So... we hit some pretty solid rock crawling a...
The 4th Gen has proven itself to be a solid...
I know fuel efficiency is always a hot topic...
