4th Gen Tacoma AlphaRex LUXX Alpha Black Initial Impressions
Just got the AlphaRex LUXX Alpha Black headlights on my 2025 TRD Offroad and they completely changed the front end. The install went smoothly overall, removing the front end was WAY easier then I thought it was going to be. Then the factory headlights pop out and you can put in the new ones. The wiring was mostly plug and play except I did have to wire the DRL harness which was just wired by some fuse taps it only took a couple minutes. Fitment is tight and everything lines up like stock.
The DRLs are seriously bright and the startup animation looks so good in person I end up staring at it every time I walk away. I went with amber which was just a simple swap on the unit. Night driving is a huge upgrade over factory way cleaner beam and better visibility without any glare.
Honestly, they make the truck look like it should’ve come this way from the factory. Check them out here: https://customsunlimited.com/produc...x-series-led-projector-headlights-alpha-black
Nice dude! I dig the DRL. I've got a set of NOVAs going on soon.
Post up some night output shots! Of the lights themselves and their output.
Will do!
So I did this to fit larger tires, but you may...
My name it Tony, researching on the 2024 for a...
FYI, new recall for Select 2025 Tacoma models...
