- Apr 29, 2025
- 2025 Tacoma TRD Offroad Long Bed Upgrade Package
Just got the AlphaRex LUXX Alpha Black headlights on my 2025 TRD Offroad and they completely changed the front end. The install went smoothly overall, removing the front end was WAY easier then I thought it was going to be. Then the factory headlights pop out and you can put in the new ones. The wiring was mostly plug and play except I did have to wire the DRL harness which was just wired by some fuse taps it only took a couple minutes. Fitment is tight and everything lines up like stock.
The DRLs are seriously bright and the startup animation looks so good in person I end up staring at it every time I walk away. I went with amber which was just a simple swap on the unit. Night driving is a huge upgrade over factory way cleaner beam and better visibility without any glare.
Honestly, they make the truck look like it should’ve come this way from the factory. Check them out here: https://customsunlimited.com/produc...x-series-led-projector-headlights-alpha-black
