ExtraQueso
- Apr 21, 2024
Confirmed true plug and play, direct swap from a TRD Pro to base level Solar octane Offroad yesterday. Very happy with the look and functionality.
Headlight tilt adjustments, Amber sequential DRLs, and day time white DRLs work!
No special harnesses or reprogramming needed. You can see that Toyota will eventually make these standard on later model years given the direct swap.
Definitely worth it if you can find a pair for a good price. Got mine for $650 locally!
Main difference is instead of a socket for the halogen bulb, it now plugs into the DRL plug in which must codes for the sequential turn signals and daytime running lights. Nothing illuminates in the once halogen bulb area part of the headlight. Hope this helps clear up the confusion a lot of us had. Toyota parts website notes these as not compatible but the schematics are exactly the same.
