2024+ Tacoma - Bed Step & Rear Step Bumper
2024+ Tacoma - Bed Step & Rear Step Bumper​
This thread covers the two bed access features on the 2024+ (4th Gen) Tacoma: the fixed rear step bumper and the deployable bed step. Information consolidated from pages 146-147 of your owner's manual, supplemented with community insights on trim availability and practical usage tips.
Tacoma Bed Step & Rear Step Bumper: Complete Guide​
Your 4th Gen Tacoma provides two distinct bed access features to make loading easier:
Rear Step Bumper (Fixed Feature)​
The rear step bumper is a fixed feature integrated into the rear bumper design. It provides rear end protection and easier step-up loading. This feature is always available and requires no deployment.
  • Location Integrated into center of rear bumper
  • Availability Standard on all 2024+ Tacoma trims
  • Deployment None needed - always ready to use
  • Best for Quick tailgate access, loading from rear
Bed Step (Deployable Feature)​
The bed step is a deployable step that extends for easier step-up loading into the bed. When not in use, it stows flush to maintain the truck's clean appearance.
  • Location Passenger-side bed corner
  • Availability Optional accessory on all trims (not standard)
  • Deployment Pull to deploy, push to stow
  • Best for Loading deep into bed, organizing cargo
Official Manual Information​
Safety & Usage Guidelines​
NOTICE: To prevent damage to the rear step bumper: Do not allow more than one person to get on the rear step bumper at a time.
- Source: Page 147
NOTICE: To prevent damage to the tailgate and rear step bumper: Avoid possible contact between tailgate and rear bumper during tailgate removal and reinstall.
- Source: Page 146
Weight Limit The manual specifies "one person at a time" for the rear step bumper. No numeric weight capacity is provided in the owner's manual.
How to Use: Rear Step Bumper​
To use the rear step bumper, step on the shaded area in the illustration.
- Source: Page 146
When to Use the Rear Step Bumper
  • Accessing tailgate latches
  • Loading cargo into the bed from the rear
  • Quick access when tailgate is closed
  • Cleaning bed rails or tonneau cover
How to Use: Bed Step​
Deploying and Stowing
  1. Deploy Pull out the bed step mechanism
  2. Stow Push the bed step back into its stored position
- Source: Page 147
When to Use the Bed Step
  • Loading cargo deep into the bed
  • Organizing items in the bed
  • Accessing tonneau cover or bed divider
  • When you need stable footing inside the bed area
Trim Availability & Design Details​
Bed Step Availability
The bed step is optional equipment on all 4th Gen Tacoma trims. It is NOT standard on any trim level (SR5, TRD Sport, TRD Off-Road, TRD Pro, Limited, or Trailhunter). This accessory can be dealer-installed or port-installed on any trim variant.
Rear Step Bumper Availability
The rear step bumper appears to be standard on all 4th Gen Tacoma models as it's integrated into the bumper design.
Design Limitations
  • The OEM bed step is passenger side only. Driver-side access requires aftermarket solutions or relocation brackets.
  • Bed step mounting location can conflict with recovery point installation for off-road use. Relocation brackets are available to solve this.
  • Despite being sold as "Toyota OEM" through dealers, the bed step is manufactured by Amp-Research.
Installation Tips (From Community)​
If you're installing an OEM bed step yourself, community members report these tips:
Correct Installation Sequence
Install the mounting bracket to the step FIRST, before attaching the bracket to the frame. Installing the bracket to the frame first will prevent you from being able to access and tighten one of the mounting bolts.
Self-Tapping Screw Caution
The kit uses self-tapping screws which are easy to strip if over-tightened. Hand-tighten until snug, then stop. Don't use excessive force with power tools, as stripped screws require drilling out and may damage the mounting bracket.
Missing Instructions
Many bed step kits (even from Toyota dealers) arrive without printed instructions. If yours is missing instructions, the installation sequence above will help you avoid the most common mistake.
Feature Comparison​
FeatureRear Step BumperBed Step
LocationRear bumper (center)Bed corner (passenger side)
DeploymentAlways availableMust deploy/stow
Best ForQuick tailgate accessInside-bed work
Trim AvailabilityStandard (all trims)Optional (all trims)
Side AvailabilityCenter (both sides accessible)Passenger side only
Practical Usage Context​
Use the fixed rear step bumper when you need quick access. It's faster than deploying the bed step and works well for loading light items near the tailgate or accessing tailgate latches.
Deploy the bed step when you need to work inside the bed. It provides better positioning for reaching forward into the bed, organizing cargo, or loading heavy items deep in the bed.
Common Use Cases
Community members report using the bed step for loading heavy items (coolers, toolboxes), organizing cargo, accessing tonneau covers, and detailed bed cleaning. The rear step bumper is preferred for quick tasks like grabbing something from the bed or reaching over the tailgate.
Common Issues & Limitations​
Recovery Point Conflict
The bed step mounts in the same location where many users install recovery points for off-road use. This forces a choice between bed access convenience and recovery capability. Aftermarket relocation brackets are now available to solve this issue for off-road-focused users.
Passenger-Side Only
Depending on your parking situation (which side faces the curb or wall), the passenger-only bed step location may be inconvenient for regular use.
Pages Covered 146-147
The manual pages for this topic include illustrations showing:
  • Shaded area on rear step bumper where to step
  • Bed step deploy/stow mechanism
  • Safety and usage notices
For visual guidance, refer to the manual illustrations on pages 146-147 of your 2024+ Toyota Tacoma Owner's Manual.
Manual Sources
  • 2024+ Toyota Tacoma Owner's Manual, pages 146-147
Community Sources
  • Tacoma4G.com Forums - 4th Gen Tacoma community
  • TacomaWorld.com Forums - Toyota truck enthusiast community
  • 4GTaco.com Forums - 4th Gen Tacoma discussion forum
Disclaimer
This thread combines official Toyota owner's manual content with community-sourced insights. All manual content (procedures, safety warnings, specifications) is presented verbatim from the owner's manual. Community tips represent user experiences and should be considered supplementary guidance. Always defer to your owner's manual for official Toyota guidance.
For safety-critical procedures or if you're unsure about any aspect of using these features, consult your Toyota dealer.
