- Jun 23, 2025
- Website
- www.tacomaforce.com
- 2024 DCSB TRD Off-Road
Peak Suspension 2-Piece Summit Kit – 4th Gen Tacoma
For most 2024+ owners, the Peak Suspension 2-Piece Summit Kit is the answer to lifting your truck... without getting into race-inspired parts (and maintenance) but still giving you adequate performance.This kit goes beyond a basic spacer lift by pairing front and rear lift components with Peak’s tubular upper control arms, giving you both the stance and the corrected suspension geometry.
The Summit Kit is designed for those who want a complete, clean, reliable lift without sacrificing drivability.
Why You Would Want It
Many entry-level lift kits can negatively affect your ride and handling, causing issues both on and off the road. The Summit Kit solves that by including tailored fit components, and upgraded UCAs from the start. Combined with front and rear lift spacers, the truck sits higher, clears larger tires, and maintains stability. It’s a practical lift that doesn’t cut corners.
Key Features
- Included UCAs: Tubular upper control arms correct suspension geometry and restore proper caster after a lift. This is an optional, but recommended part.
- Two-Piece Front Design: Uses a top mount spacer and lower spring adapter for balanced lift and reduced preload stress.
- Rear Coil Spacers: Available in 1" or 2" to level the truck.
- Construction: CNC-machined, anodized aluminum spacers and heavy-duty tubular steel uniball control arms.
- Bolt-On Installation: Installs with standard tools, no cutting or welding required.
Why Get This Instead of a Full Suspension Overhaul?
A full suspension system with coilovers and aftermarket shocks delivers maximum adjustability, but it comes with a much higher price tag, more complex installation, and ongoing maintenance. The Summit Kit gives you the essential lift and geometry correction at a fraction of the cost by using your factory struts, shocks, and springs. By including UCAs, it covers the most critical alignment concerns without requiring you to replace every major component. It’s a simpler, more affordable solution that still delivers reliable performance for daily driving, weekend trails, and larger tire fitment.
Why We Recommend It
The Peak Suspension 2-Piece Summit Kit is our first (affordable) choice to lift the 4th Gen Tacoma. This full kit rides great, fits like OEM, and the quality of the materials ensures it will hold up long-term. It’s a smart investment if you’re planning to run larger tires or want a more aggressive stance without compromising daily drivability.
Product Review
This kit really is the complete solution. The front and rear spacers paired with the tubular upper control arms made the lift straightforward, and the drivability was not negatively affected in any way.
The install process was simple, everything was included, and it bolted up without any surprises. Once on, the stance looked right, the extra clearance was helpful, and the handling stayed predictable. For us, it checked all the boxes of what we wanted out of a lift without going into a full suspension overhaul.
If you’re looking to lift your Tacoma and want something easy to install, reliable long-term, and engineered to address geometry the right way, this is the kit.
Check out the 2.25" Peak Lift Kit at TacomaForce.com: https://www.tacomaforce.com/products/2-piece-summit-kit-lift-4th-gen
Shoutout to @rustytaco for the killer photography!
Call/email us anytime to talk with the experts
We offer FREE build consultations!!
(916)-805-6432
info@tacomaforce.com
4th gen Tacoma force peak suspension lift kit_0003_Layer 3.jpg296.9 KB · Views: 19
4th gen Tacoma force peak suspension lift kit_0001_Generative Fill 2.jpg178.8 KB · Views: 20
4th gen Tacoma force peak suspension lift kit_0002_Layer 4.jpg231.2 KB · Views: 14
4th gen Tacoma force peak suspension lift kit_0005_Layer 1.jpg322.9 KB · Views: 13
4th gen Tacoma force peak suspension lift kit_0004_Layer 2.jpg314.9 KB · Views: 13
