Roof Rack Options for 4th Gen Tacoma
Best Roof Racks for the 2024+ Tacoma​
I’ve been digging into roof rack options for the new Tacoma and figured I’d share what I found in one place to hopefully help others out. Roof racks are one of those upgrades that can totally change how you use the truck: more space for gear, a spot for a rooftop tent, and mounting for lights or recovery boards. Some keep a low profile and look almost factory, others sit taller and give you all the clearance you could ever want. The right one really comes down to how you plan to use your truck and how much gear you’ll be carrying.
Things to Consider​
Rack height and how much wind noise or drag you’re willing to live with
Mounting system style: slots, crossbars, modular side plates
Strength and weight ratings if you plan to run a rooftop tent
Sherpa Rainier​
Sherpa’s Rainier is built from aircraft-grade aluminum and stainless hardware, designed as a no-drill bolt-on system for the 2024+ Tacoma. It’s one of the strongest options out there while still keeping a sleek look.
  • Seven crossbars with lots of mounting space
  • 300 lb dynamic / 700 lb static load rating
  • Powder coat finish with anodized crossbars
Check price online: LINK HERE
Prinsu Pro​
Prinsu’s rack is a favorite for modularity with its adjustable crossbars and drop-point slots for accessories. It installs using factory mounting points and has solid load ratings for gear and tents.
  • Fully modular aluminum design
  • Dynamic rating around 600 lb, static near 1000 lb
  • Edge trim included to help cut wind noise
KC HiLiTES Platform One​
KC stepped into the rack game with the Platform One, and it’s built tough with a clean modular design. It’s a good choice if you want something fresh in the space with the KC brand behind it.
  • All aluminum construction with modular crossbars
  • Integrated channels for light wiring
  • Designed for rooftop tents and overland gear
Backwoods DriftR​
Backwoods designed the DriftR to be clean and functional without adding unnecessary bulk. It gives you plenty of utility and matches nicely with their other Tacoma armor.
  • Wraparound side plates that fit body lines
  • Extrusion channels for mounting gear
  • Works well with rooftop tents
Cali Raised LED​
Cali Raised built their premium rack as a balanced choice for everyday use and overland setups. It has plenty of mounting surface and a clean design that fits the Tacoma’s roof well.
  • Powder coated construction
  • Multiple slots for lights and gear
  • Built to blend into the truck’s profile
DV8 Offroad​
DV8 kept their rack low profile but still functional with integrated mounts. It’s a solid option if you want a more subtle look that still works for tents and accessories.
  • Extruded aluminum crossbars
  • Bolt on using factory roof holes
  • Accessory mounts built into side plates
Westcott Designs​
Westcott went for a lower-profile rack that doesn’t make the truck look too tall. It’s a good pick if you want the benefits of a rack without changing the stance much.
  • Subtle height increase over stock
  • Bolt on install
  • Works with most common roof accessories
Rough Country​
Rough Country’s rack is the budget choice that still gets the job done. It offers a unique side profile with modular mounting for any of your gear.
  • Steel construction with powder coat
  • Mounting slots for accessories
  • Simple and affordable option
Frontrunner Slimline II​
Frontrunner’s Slimline II is a flat platform rack that’s known for its accessory ecosystem. It’s a strong rack that doubles as a deck for carrying boards, jerry cans, or just about anything else.
  • Deck style modular system
  • RTT capable with heavy cargo support
  • Tons of compatible accessories
Victory 4x4​
Victory’s rack leans heavy on aggressive styling with plenty of strength. It’s a solid option if you want your rack to look as serious as it functions.
  • Steel side plates with modular slots
  • Built for rooftop tents and heavy gear
  • Strong styling to match overland builds
Final Thoughts​
I noticed quickly that roof racks for the Tacoma really split into two camps low profile daily friendly designs and heavier duty setups meant for serious gear hauling. Some go all in on modularity, others keep things straightforward and strong. Thinking about your own setup, the kind of trips you’ll be doing, and how much weight you want up top will make the right choice clear.
Tailgate Panel Buyers Guide for the 2024+...
Top 10 Tonneau Covers for 2024+ Tacoma I’ve...
Has anyone tried this 3D-printed shim for the...
Fog & Fang Light Buyers Guide for the 4th Gen...
I had just seen online how many people’s...
Top 6 Bed Stiffener Options for the 2024+...
Top 7 Ditch Light Brackets for the Tacoma I...
Has anyone had any luck running aftermarket...
I’ve been looking at that tailgate assist kit...
Camper Shell Options for 2024+ Tacoma I’m...
