- Apr 29, 2025
I have been running the SXTH Element Trail pipe for the 2024+ Tacoma for a couple of weeks now, and I couldn't be happier. I have a double Long-Bed, which kind of makes the off-road part a bit harder. With the extra overhang, I am constantly worried about bashing the backend down on simple inclines or rocks. I eventually snagged my exhaust and I had to figure out a fix before it became a lot more expensive.
I found the SXTH Element Trail Pipe and it did exactly what I wanted for a lot cheaper than I thought. It was a super easy swap. I dropped the spare, unbolted the factory resonator, and this bolted right in. Took maybe 10 minutes start to finish. The build is solid. Honestly, it’s nicer than I expected, it has a stainless steel construction, great welds, and just looks clean once it’s on.
I didn't notice any sound change really, maybe just a bit more on cold start but it is still really quiet.
The stock exhaust just hangs too low, and if you want to go off-road at all I would say this is a necessary mod for any Tacoma.
If you want one, you can get 5% off at TacomaForce with code TRAILSXTH.
Check It Out: https://www.tacomaforce.com/products/2024-toyota-tacoma-off-road-trail-pipe
