Best Entry Level Lift Kits 4th Gen Tacoma
Best Budget Lift Kits for the 2024+ Tacoma​
When picking an entry-level lift kit for your Tacoma, the first step is figuring out your goals. Do you just want the truck to sit a little taller for daily driving and looks? Are you trying to clear a specific tire size without major trimming? Or do you plan on wheeling the truck hard and need the extra geometry correction for off-road performance?
Basic lift kits usually rely on spacers and preload collars. These raise the truck at a lower cost and keep your factory shocks, but they don’t always address suspension geometry. That’s where upper control arms (UCAs) come in. A kit that includes UCAs gives you better alignment numbers and ball joint angles, which pays off in tire wear, steering feel, and long-term durability.
Entry kits also differ in how much height they provide. A modest 2–2.5" lift often keeps the truck driving close to stock and only needs an alignment. Going 3" or higher usually requires extra parts like differential drops, track bar brackets, or bump stop spacers. The higher you go, the more you’re stepping toward a full suspension setup.
Knowing your target tire size, budget, and how much effort you want to put into the install will help narrow down which kit is best for your truck.
Peak Suspension – 2-Piece Summit Kit​
Best lift kits for the 4th gen Tacoma_0002_Peak Suspension 2 piece collar lift 4th gen Tacoma ...jpg
This kit lifts the Tacoma about 2.25" up front using a two-piece design and gives you the option of 1" or 2" rear spacers. Tubular UCAs are included to keep alignment and geometry in check.
  • 2.25" front lift
  • 1" or 2" rear spacers
  • Tubular UCAs included
  • Clears up to 35" tires with proper offset
Find it online at Tacoma Force: https://www.tacomaforce.com/products/2-piece-summit-kit-lift-4th-gen
Ironman 4x4 – 3" Lift & Level Kit​
A budget spacer setup that nets about 3" of lift in the front and 1" in the rear. Good for stance and bigger tires if you’re running a coil-rear Tacoma.
  • 3" front, 1" rear
  • Strut, coil, and preload spacers
  • Fits coil-spring rear models only
  • Bolt-on install
Find it online: https://www.ironman4x4.com/products/3-lift-level-kit-toyota-tacoma-2024-76119001
Westcott Designs – Preload Collar Lift Kit​
This preload collar system reuses your factory shocks and springs to keep the ride close to stock. It provides a modest lift without needing UCAs.
  • 2.50" front, 0.75" rear
  • No UCA required
  • CNC-machined collars, anodized finish
  • Fits up to 35" tires with proper offset
Find it online: https://westcottdesigns.net/product...d-collar-lift-kit-trd-off-road-trd-sport-sr5/
Rough Country – 3.5" Lift Kit​
A taller more intensive entry-level package that raises the Tacoma 3.5" and includes geometry assist. Comes with upgraded UCAs.
  • 3.5" lift
  • Upper control arms included
  • Bolt-on install
Find it online at Tacoma Force: https://www.tacomaforce.com/products/4g-tacoma-3-5-inch-lift-kit-trd-offroad
ReadyLIFT – 3" SST Lift Kit​
This kit delivers 3" in the front and 2" in the rear with spacers and includes UCAs. ReadyLIFT provides clear tire fitment charts up to 35s with the right wheel offset.
  • 3" front, 2" rear
  • Diff drop, shock extenders, bump stops
Find it online: https://www.readylift.com/3-sst-lift-kit-toyota-tacoma-2024.html
Don’t Forget the Track Bar Angle​
Anytime you lift the rear of your Tacoma, you change the angle of the track (panhard) bar. When that angle gets too steep, it will result in unstable handling. The fix is a relocation bracket that raises the axle-side mount and levels things back out. The best option right now is the DR.KDSS Bracket, which I’ve already done a full write-up on here: Track Bar Relocation Upgrade by DR.KDSS
Find it online at Tacoma Force: https://www.tacomaforce.com/products/botck-trackbar-relocation-kit-4th-gen-tacoma
Final Thoughts​
Entry-level lift kits are all about trade-offs: cost, height, and how much you want to mess with alignment and install. If you want to keep things simple, Westcott or Peak are easy choices. If you want more height, Rough Country or ReadyLIFT will get you there, just be ready for more changes. Ironman is the cheapest way up, but you’re skipping UCAs. Pick based on how you’ll use your truck and the tires you want to clear.
Hell yeah dude, thanks for putting this one together. Running the Peak collar kit on my 6th Gen 4R right now. It's been a great little budget kit to get the 4Runner off the ground. I know this is the Taco forum, but here's the 4Runner out wheeling the other day on that kit.
Some shots of Martec and I wheeling the other day. I actually kept up with some pretty stupid lines Nick was taking in his new SAS 1st Gen Tacoma last weekend.
Also, Dobinsons just dropped their kit for the 4th Gen Tacoma... IMS is somewhat of a budget kit, and then the MRR gives you 3-way adjustability: high-speed compression, low-speed compression, and rebound. Large remote reservoir for superior cooling and oil volume. Fully rebuildable and revalvable for long-term performance with 6061 aluminum parts and high-temp fluids.
Dobinsons 1-3″ IMS Lift Kit for Toyota Tacoma 2024 On: $2150​
Dobinsons 1-3″ MRR 3-Way Adjustable Lift Kit for Toyota Tacoma 2024 On: $3500​
Solid list. Depends on what you mean by "entry level". Dirt King just dropped some new 2.0 kits. Good performance for the price! Also around $2k for coilovers and shocks alone. I know Bilstein has some stuff too. Also ARB. And Peak. There's some solid options on the market between $1-2k. Depending on how much you lift, I would also recommend UCAs. But you can't go wrong with something like the Peak kit. I have that setup currently. Been really solid and the factory OR suspension works well with the kit.
Hi guys got a 2024 trd sport 4x4 p 265 65 R 18...
This thread expands on pages 143 and 641 of...
Tacoma Safety System Volumes: Adjust Buzzer...
This thread unifies smart key system...
