OEM Style Switch Panel for 2024+ Tacoma – Factory Fit for the Cali Raised 8 Switch System
Cali Raised LED
VENDOR
Fortworth, TX
caliraisedled.com
Parts Offered
Rock Sliders, Bed Racks, Bumpers, Skid Plates, Lighting & More
2024 DCSB TRD Off-Road
Wiring up lights, air systems, or other trail gear in your 2024+ Tacoma? This OEM Style Switch Panel from Cali Raised LED is a direct-fit solution that replaces the factory dash tray with a clean, purpose-built mount for the Cali Raised 8 Switch Control System. No cutting, no drilling—just factory-style integration that looks and feels OEM.
Highlights:
  • Fits all 2024+ Toyota Tacoma trims
  • OEM-style snap-in design – uses stock mounting points
  • No modifications required – drop-in install with no tools needed
  • Injection-molded ABS plastic – 1/8" thick, built to handle heat and trail abuse
  • Factory-matched texture – blends right into the interior
Install Overview:
  • Installs in under 10 minutes
  • Compatible only with the Cali Raised LED 8 Switch Control System
  • Designed to replace the center storage tray in the dash
Does it fit other switch types?​
No—this specific panel is molded to fit the Cali Raised 8 Switch Control System only. If you’re looking to run standard Toyota-style tall switches, check out our alternate switch panel for 2024+ Tacomas.
What's the benefit of this panel?​
It gives you clean, central control over your rig’s electrical accessories with no mess of universal mounts or holes drilled in your dash.
For a factory-style solution to manage your trail gear, check out the OEM Style Switch Panel for 2024 Toyota Tacoma—designed for the Cali Raised 8 Switch Control System and built to handle serious use.
Heck yeah! Got mine waiting to wire up all my new KC lights. I'll be posting more about this too.
Nice! Once you get those KC lights wired up, post some night shots—would love to see how your setup turns out. If you're running a Cali Raised switch panel or relay system to manage everything cleanly, that could be worth highlighting too.
I will absolutely be sharing everything. Yes, I have the switch panel too, the whole setup. Will start posting soon once the lights land.
Hey everyone, We’re excited to join the...
1000 miles on portals - here's the truth so...
TRD off-road with upgrade package and SDM...
Bunch more posts to come of the recent changes...
Hey guys! I picked up Underground Tacoma...
Yo guys, just a heads up... the 4th Gen Tacoma...
