- Mar 26, 2024
- Sacramento, CA
- YouTube
- Visit YouTube
- 13' DCSB TRD OR
Looking for the best rock sliders for the 2024+ 4th Gen Tacoma? Key factors to consider are kick-outs for extra protection versus no kick-outs, DOM vs. HREW tubing for strength, top plates vs. no top plates, and angled versus non-angled sliders. If you could choose any brand/style/design out of the options below, which one would you take and why?
In no specific order, here are some of the best rock sliders for the 24+ Tacoma.
The C4 Fabrication Rock Sliders are built with square and DOM tubing, these sliders are designed to take hits and hold up over time. The optional serrated step plates add grip for everyday use without getting in the way on the trail.
Quick Specs:
The Cali Raised LED Step Edition sliders give you solid tubing with an integrated filler plate, making them practical for everyday use while still built for the trail. If you prefer a more tucked, angled design, the Trail Edition version is also available with about a 20° angle for better clearance.
Quick Specs (Step Edition):
RCI Metal Works Rock Sliders use 2″ square tubing with welded gussets for added strength, with the option of a flatter step or a steeper angle for clearance. Built to handle full side support, they’re designed to protect rocker panels and doors while staying functional for everyday use.
Quick Specs:
Westcott Designs Rock Sliders are built from .120-inch wall tubing with laser-cut steel frame plates, hand-welded for strength and precision. They’re available in either a flat 0° setup or a 20° angle, with optional top plates that add grip and a bottle opener.
Quick Specs:
Find Them Online: https://westcottdesigns.net/product/2024-toyota-tacoma-4wd-short-bed-rock-sliders/
Southern Style Offroad sliders are built from laser-cut 3/16" wall square tubing and hefty 1/4" mounting plates, all powder-coated matte black with a 0° kick-out design and dimple-die top plates to help with traction even in muddy terrain.
Quick Specs:
Find Them Online: https://southernstyle-offroad.com/collections/tacoma-2024-up
The CBI Offroad Fab Overland Bolt-On sliders are built tough with heavy-duty DOM tubing and offer either a flat top-plate step or a sleek angled profile. They bolt up in about an hour, fit both 5' and 6' double-cab beds (excluding 2WD models)
Quick Specs:
Find Them Online: https://cbioffroadfab.com/product-category/toyota/tacoma/tacoma-rock-sliders-side-steps/
NYTOP Rock Sliders use a flat-panel design instead of traditional tube work, giving a clean low-profile look with plenty of strength. The flat top surface doubles as a step, while the angled underside helps the truck slide over obstacles without catching.
Quick Specs:
Find Them Online: https://nytop.com/toyota-tacoma-accessories-store
Restless Off-Road Rock Sliders offer serious strength with 1.75″ .120 wall DOM tubing plus gussets and plates, offering adjustable protection that also serves as a functional step. These sliders come with built-in rock light brackets and versatile angled or top-plate options.
Quick Specs:
Find Them Online: https://www.restlessoffroad.com/
1. C4 Fabrication
Quick Specs:
- 2" x 2" square tubing main body
- 1-3/4" DOM round tubing support
- Optional stainless step plates
- Raw steel or powder-coated finish
2. Cali Raised LED
- 1.75″ DOM tubing, 0.120″ wall
- Optional kick-out or no kick-out
- Aluminum filler plate, 0.09″ thick
- Bolt-on install with Grade 8 hardware
- Finish options: raw, powder-coat, or bedliner
- Angled design at ~20°
3. RCI Off-Road
Quick Specs:
- 2″ square main tube with 1.75″ DOM outer rails
- ¼″ gussets on all four legs with 3/16″ frame plates
- Laser-cut 3/16″ steel end caps
- Bolt-on install, no drilling
- Hi-lift capable and built to protect rocker panels and doors
4. Westcott Designs
Quick Specs:
- .120″ wall HREW or DOM tubing
- Laser-cut .188″ steel frame plates
- MIG or TIG welded construction
- 0° flat or 20° angled design
- Optional top plates with stainless accent and bottle opener
5. Southern Style Off-Road
Quick Specs:
- 1/4" thick mounting plates
- Laser-cut 3/16" wall square tubing
- 0° kick-out configuration
- Dimple-die top plates for traction
- Grade 10.9 hardware included
6. CBI Off-Road
Quick Specs:
- Heavy-duty DOM tubing construction
- Flat top-plate or angled options
- Configurable for Double Cab, 5′ or 6′ bed
- Finish choice: bare metal or black powder coat
- Supports vehicle weight for jacking or recovery
7. NyTop
Quick Specs:
- 3/16″ and 1/4″ high-strength steel construction
- Flat 3″ step surface
- 25° angled underside
- TIG-welded design
- Supported up to 3 metric tons during testing
8. Restless Off-Road
Quick Specs:
- 1.75″ DOM round tube, .120″ wall
- ¼″ gussets and 3/16″ mounting plates
- Angle options: 1/8″ kick-out or full top plate add-on
- Built-in rock-light mounting brackets
- Uses Grade 8 hardware; bolt-on to existing frame
- Will not fit KDSS or X-reas models
