YotaVerse Replica TRD Pro Grille with Light Bar - Review
757Tacoma
2025 DCSB TRD Sport
I went ahead and changed out my TRD Sport Grille for a YotaVerse Replica TRD Pro Grille!
It fully changed the way the truck looks. It makes the front end look completely different. Upgrading the grille on your Tacoma is a major plus. Not only does it elevate the truck’s appearance and make it stand out from the crowd, it helps with visibility because of the light bar that is included! Whether you're looking to personalize your ride, improve its performance, or simply add an extra bit of lighting for off-roading, an upgraded grille is one of the best investments you can make. Plus, it’s an easy upgrade that completely changes the front end appearance as well as performance. I 100% recommend getting the TRD Pro Grille over the OEM Grille any day!
I chose the grille with the raptor lights & light bar for off-roading purposes and helping with visibility when I am not on the pavement.
It takes approximately 1-2 hours to change out the grille, with basic tools needed and it is a simple 1 person job.
Tools needed - Phillips head and flat head screwdriver, 10mm, and trim pry tool.
Direct link for this product - https://www.yotaverse.com/products/tacoma-trd-pro-grill-2024
I will be adding an update to this post once the light bar is fully wired up & showing the output!
Direct link for this product - https://www.yotaverse.com/products/tacoma-trd-pro-grill-2024?variant=45868478365925
View attachment 2298View attachment 2296View attachment 2297
How long did the install take?
It took me about 2 hours with recording / taking pictures of the whole process. But it would take max 1 hour without having to stop every step.
Looks great dude! You should put some yellow Lamin-x on the light bar to match the fogs!
Did you have to buy a separate camera bracket or does this grille come equipped for the camera install?
I have the same grille, just no raptor lights. It came ready to accept the front camera without needing to buy anything extra.
Does Lamin-x hold up pretty well? I've been thinking of doing it for my fogs.
It does. I ran yellow on a bunch of Lightforce light bars and pods. Never peeled, not even a little bit.
