- Nov 19, 2025
- 4th Gen Tacoma
Everything you need to use the wireless charging pad effectively and troubleshoot common issues.
Your 2024+ Tacoma includes a factory wireless charging pad integrated into the center console. This Qi-standard compatible charger allows you to charge smartphones and mobile batteries by simply placing them on the charging tray-no cables required.
The charger uses the Qi wireless charging standard established by the Wireless Power Consortium. You can verify compatible devices at https/www.wirelesspowerconsortium.com/
Source: Page 473
WARNING - To prevent malfunctions or burns
Observe the following precautions. Failure to do so may result in equipment failure and damage, catch fire, burns due to overheat or electric shock.
Do not insert any metallic objects between the charge area and the portable device while charging. Do not attach an aluminum sticker or other metallic object to the charge area. Do not attach an aluminum sticker or other metallic object to the side of the portable device (or to its case or cover) that touches the charge area. Do not use the charging tray as a small storage space. Do not subject to a strong force or impact. Do not disassemble, modify or remove. Do not charge devices other than specified portable devices. Keep away from magnetic items. Do not charge devices if the charge area is covered in dust. Do not cover with a cloth or similar material.
Source: Page 480
WARNING - Caution while driving
When charging a portable device, for safety reasons, the driver should not operate the main part of the portable device while driving.
Source: Page 479
WARNING - Caution while in motion
Do not charge lightweight devices such as wireless headphones while in motion. These devices are very light and may be ejected from the charging tray, which may lead to unforeseen accidents.
Source: Page 479
WARNING - Caution regarding interference with electronic devices
People with implantable cardiac pacemakers, cardiac resynchronization therapy-pacemakers or implantable cardioverters, as well as any other electrical medical device, should consult their physician about the usage of the wireless charger.
Source: Page 479
Basic Operation
Using your Tacoma's wireless charger is straightforward:
Understanding the Charging Coils
Both your device and the wireless charger contain charging coils. The charger's coil position automatically adjusts to locate your device's charging coil. Charging works as long as the center of your device's charging coil aligns within the charging area.
Important note: Don't place two or more devices on the tray at the same time. The charger's coils can fail to detect multiple devices, preventing either from charging properly.
The Recharging Function
When charging completes and your device enters a "charge suspension" state, the charger automatically restarts charging after a fixed time period. If you move your device significantly in the charge area, the charging momentarily disconnects and charging stops. However, once the charger detects the coil again, it moves toward it and charging automatically restarts.
Source: Pages 474-475
Your Tacoma's charger supports rapid (fast) charging for compatible devices. Your device automatically triggers fast-charging mode when you place it on the tray-no configuration needed.
Devices that support rapid charging:
Source: Page 475
Operating Requirements
Your wireless charger operates only when the engine switch is in the ACC (Accessory) position or the ON position. The charger doesn't function when the engine is off or the multimedia system is powered down.
Power Output Specifications
Your Tacoma's charger delivers different power levels depending on your device:
Note: While your charger supports the Qi wireless charging standard, compatibility isn't guaranteed for all Qi devices. If a device claims Qi compatibility but won't charge, check that device's owner manual.
Thermal Behavior
When charging, both the charger and your device get noticeably warmer. This is normal. The system includes temperature monitoring, and a fan may activate to cool the charger. Your device may automatically reduce charging speed or stop if it gets too warm-this protects the battery. If charging stops due to heat, wait for the temperature to drop, then place your device back on the charger.
Source: Page 478
Community Best Practices
What the Indicator Light Means
Common Issues and Solutions
Why Charging Might Not Work
Check these common reasons if your charger isn't working:
Source: Page 480
Cleaning the Wireless Charger
Wipe the charger with a dry, soft cloth. Don't use liquid cleaners. Ensure the charging area is free of dust before use. Refer to page 511 of your manual for detailed interior cleaning procedures.
Important Operating Notes
Source: Page 479
Owner's Manual Pages
Community Sources
Disclaimer
This guide is derived from the official 2025 Toyota Tacoma Owner's Manual (Document: OM04041U) with supplementary information from the Tacoma owner community. Always follow your official owner's manual for warranty compliance and most current information. This is a reference guide only.
Tacoma Wireless Charger: Setup, Use & Troubleshooting
What Is the Wireless Smartphone Charger?
Source: Page 473
Safety Precautions
Source: Page 480
Source: Page 479
Source: Page 479
Source: Page 479
How to Use the Wireless Charger
Basic Operation
- Place your device on the charging tray with the back (charging side) facing down
- Center the device in the middle of the charge area (approximately 3.9 inches wide × 1.0 inch deep)
- Watch the indicator light: Orange means it's actively charging, green means charging is complete or the charger is on standby
- Your device can stay on the tray after charging completes-it won't overcharge
Rapid Charging Support
- iPhones: iPhone 8 and later models with iOS versions that support 7.5W charging
- Galaxy devices: Galaxy phones compatible with Galaxy's proprietary rapid charging standard
- WPC-compliant devices: Portable devices compliant with WPC Ver1.3.2 with EPP (Extended Power Profile) output
Source: Page 475
Charging Specifications
- Standard charging: 5 watts or less (default for most Qi-standard devices)
- iPhone rapid charging: Up to 7.5 watts (iPhone 8 and later with compatible iOS)
- Galaxy rapid charging: Up to 10 watts (Galaxy phones with rapid charging standard)
- EPP devices: Up to 15 watts (devices compliant with WPC standard Ver1.3.2)
Thermal Behavior
Source: Page 478
Real-World Tips & Context
- Remove thick cases: Thick protective cases reduce power transfer efficiency significantly. Thin cases are generally acceptable.
- Center your device precisely: The charger has limited range (about 1-2mm). Centering keeps proper coil alignment.
- Turn off Adaptive Charging if needed: Some phone models have battery protection features that halt charging if they detect power cycling.
- Clean the charging pad regularly: Use a microfiber cloth and wipe periodically. Dirt and debris reduce charging efficiency.
- Monitor phone temperature: Simultaneous charging plus wireless Android Auto can cause excessive heat, triggering device protection shutdown.
- Experiment with positioning: Some phone models may need to be positioned higher or offset slightly on the pad.
- Using thick protective cases: This reduces power transfer by 50-75%, causing very slow or no charging.
- Leaving a phone charger cable connected: Some phone models don't wireless charge when a USB cable is detected.
- Pressing down hard on the device: This can damage both the wireless charger and the device.
- Using the truck in extreme heat while actively charging: The charger itself generates heat. Combined with cabin heat, this can trigger thermal shutdown.
- Expecting rapid charging from newer flagship phones: Your charger maxes at 15W, but newer flagship phones expect 20-30W+. You may experience what users call "trickle charging" with newer devices.
Troubleshooting: When the Charger Doesn't Work Properly
| Light State | Meaning | What to Do |
| Off / Disappears | Multimedia power off or engine off | Start engine or turn on multimedia system |
| Green (steady) | Standby or charging complete | Device is ready to charge or fully charged |
| Orange (steady) | Actively charging | Normal operation-let charging continue |
| Green (steady) + Blue on screen | Smart key detection in progress | Wait for key detection to complete |
| Orange (flashing 1/sec) | Vehicle ↔ charger communication failure | Turn engine off, wait a few seconds, then restart |
| Green (flashing 1/sec) | Charger ↔ multimedia system failure | Turn engine off, wait a few seconds, then restart |
| Orange (flashing 4x continuously) | Temperature safety shutdown | Remove device immediately, wait for cooling (5-10 min) |
- Foreign Metallic Substance Detected: If the charger shows green but the multimedia screen shows gray, a metallic foreign substance is in the charge area. Remove coins, metal objects, or other debris.
- Device Not Centered on Tray: If charging fails, remove the device, wait 5 seconds, reposition it centered on the charger, and try again. Remove cases if present.
- Smart Key Detection Delay: If the tray shows green and the multimedia screen shows blue, the smart key system is detecting your electronic key. This is temporary; charging will resume automatically once detected.
- Device Too Hot: If the charger shows orange flashing 4 times continuously, temperature has exceeded the safe limit. Stop charging immediately, remove the device, and wait 5-10 minutes for cooling before trying again.
- Device is fully charged
- Device is being charged with a USB cable plugged in simultaneously
- Foreign matter (dust, debris, liquid) is between the charge area and device
- Device has overheated from charging and activated protective shutdown
- Ambient temperature is 95°F (35°C) or higher
- Device is positioned with charging side facing up (should face down)
- Small device (like foldable phones) is misaligned from the charge area center
- Device is physically larger than the charging tray
- Device's camera lens protrudes 0.12 inches (3 mm) or more from the device surface
- Vehicle is in area with strong electrical interference (near TV towers, power plants, airports)
- Thick cases or covers are attached to the device
Source: Page 480
Maintenance and Care
- Electronic key required: If the electronic key can't be detected inside the vehicle, charging can't occur. This is a security feature.
- Door opening: Opening doors while charging may temporarily suspend charging. Charging resumes automatically when doors close and the key is re-detected.
- Operation sounds: You may hear sounds when power turns on or while the device is being identified. This isn't a malfunction.
- Smart key interference: During charging, if the smart key system searches for the electronic key, charging may temporarily suspend. When detected, charging automatically resumes.
Source: Page 479
- Feature overview: Page 473
- Operating procedures and charging placement: Pages 474-475
- Indicator light meanings: Pages 475-476
- Error codes and troubleshooting: Pages 476-478
- Specifications and operating requirements: Page 478
- Smart key integration and operating notes: Page 479
- Safety warnings and precautions: Page 480
Community Sources
- 4thgentacoma.com - Tacoma enthusiast forum
- Tacoma4g.com - 4th Generation Tacoma forum
- Tacomaworld.com - Tacoma community
- ToyotaNation.com - Toyota owner community
Disclaimer
