portalhunter
- Dec 4, 2024
- Arizona
- Website
- www.instagram.com
- 2024 Tacoma Trailhunter
What's up everyone — I'm Bob, running a 2024 Tacoma Trailhunter on 74Weld Gen2 portal axles, King 2.5" remote reservoirs, 37" Toyo RT Trails, and a COBB Accessport tune from CAMTuning Performance. Going to be posting more frequently here — figured I'd kick things off with something useful.
The truck is hitting 30,000 miles, which means dealer service time. If you're running a COBB AP with a custom tune, there's an extra step before you hand the keys over: uninstalling the AP to return the ECU to stock. Here's the full process.
Why You Need to Uninstall Before Dealer Service
The AP "marries" to your ECU — it stores the factory calibration and overwrites it with the tune. If a dealer performs a factory ECU update while the AP is still installed, the stored calibration becomes invalid. You'd need to re-pair from scratch, and your tune maps may need revision.
The simple fix: uninstall before service, reinstall after. Takes 15 minutes total.
The Uninstall Process (Before Service)
What you need:
Step 1: Connect the AP to your computer via USB. Open Accessport Manager and check for firmware updates. You want the device current before any flash operations.
Step 2: Plug the AP into the OBD-II port (under the dash, driver side). Let it boot and recognize the vehicle.
Step 3: Navigate to Uninstall. The AP will read back the factory calibration, rewrite the ECU with stock mapping, restore the TCU to factory, and unpair itself.
Important: The CAN bypass harness is NOT required for uninstall. Just the AP and the OBD port.
Step 4: Do not interrupt power during the flash. Don't turn the key, don't unplug the AP. Let the progress bar complete — about 5-10 minutes.
Step 5: Once the AP shows "unmarried," turn key off, unplug, done. The truck is running stock calibration and safe for the dealer.
Pro tip: Store the AP somewhere safe while it's at the dealer. I keep mine in the center console.
The Reinstall Process (After Service)
Once you get the truck back, it's time to re-marry the AP. This is essentially the initial install process again.
Step 1: Check if the dealer flashed any ECU updates (check your service paperwork). If ECU/TCU firmware changed, the AP will detect the new calibration during install — this is normal.
Step 2: Install the CAN bypass harness — unlike uninstall, this IS required for reinstall. It isolates the CAN bus during the write.
Step 3: Plug in the AP, select Install, choose your tune map. For a CAMTuning remote tune, this is typically Stage0 – Simulated Stock TCM.
Step 4: Follow all wait timers exactly. The ECU needs time between module writes to reinitialize. Rushing the wait timers = communication errors.
Step 5: After the flash completes:
That last step is critical. Skipping the CAN terminator causes network communication errors. Dashboard warnings, weird behavior — don't skip it.
Step 6: Start the truck, let it idle, check for warnings (temporary ones are normal). Take it for a short drive — the ECU needs a few drive cycles to relearn.
Tips from Experience
30K Service Rundown
For reference, here's what the Tacoma is going in for:
Nothing exotic, but at 30K with portals, 37s, Kings, and a tune — good to have Toyota's eyes on the basics.
Full write-up with more detail: truck.bdigitalmedia.io
Instagram: @portal.hunter
Anyone else running the COBB AP on their 4th gen? Curious what tunes and tuners people are using.
What you need:
- COBB Accessport (married to the vehicle)
- OBD-II port access (driver side, under the dash)
- 15 minutes
- Key in the ignition, engine OFF
- Key OFF
- Unplug the Accessport
- Remove the CAN bypass harness
- Reinstall the factory CAN terminator block
- Keep Accessport Manager updated — outdated firmware is the #1 cause of flash errors
- Enable Auto Off — the AP draws power from OBD even when the truck is off (how to enable)
- Back up your tunes — if the dealer does a major ECU update, your tuner may need to revise for the new firmware
- Dashboard warnings are normal after flashing — should clear within a key cycle or two
- Communication errors? Almost always the CAN terminator. Reinstall it, key off 30 seconds, re-select your map
30K Service Rundown
- Oil and filter change (0W-20 synthetic)
- Tire rotation (37" Toyo RT Trail on portals — the dealer loves these)
- Multi-point inspection
- Air filter check/replace
- Drive belt inspection
