Top 8 Rock Sliders for the 2024+ 4th Gen Tacoma
  • Thread starter Thread starter BG
  • Start date Start date
  • Featured
BG
Sacramento, CA
13' DCSB TRD OR
Looking for the best rock sliders for the 2024+ 4th Gen Tacoma? Key factors to consider are kick-outs for extra protection versus no kick-outs, DOM vs. HREW tubing for strength, top plates vs. no top plates, and angled versus non-angled sliders. If you could choose any brand/style/design out of the options below, which one would you take and why?
In no specific order, here are some of the best rock sliders for the 24+ Tacoma.
1. C4 Fabrication​
The C4 Fabrication Rock Sliders are built with square and DOM tubing, these sliders are designed to take hits and hold up over time. The optional serrated step plates add grip for everyday use without getting in the way on the trail.
Quick Specs:
  • 2" x 2" square tubing main body
  • 1-3/4" DOM round tubing support
  • Optional stainless step plates
  • Raw steel or powder-coated finish
Find Them Online: https://c4fabrication.com/collections/tacoma-2024
2. Cali Raised LED​
The Cali Raised LED Step Edition sliders give you solid tubing with an integrated filler plate, making them practical for everyday use while still built for the trail. If you prefer a more tucked, angled design, the Trail Edition version is also available with about a 20° angle for better clearance.
Quick Specs (Step Edition):
  • 1.75″ DOM tubing, 0.120″ wall
  • Optional kick-out or no kick-out
  • Aluminum filler plate, 0.09″ thick
  • Bolt-on install with Grade 8 hardware
  • Finish options: raw, powder-coat, or bedliner
Quick Specs (Trail Edition):
  • Angled design at ~20°
Find Them Online: https://caliraisedled.com/collections/2024-toyota-tacoma-bumper-sliders-skids
3. RCI Off-Road​
RCI Metal Works Rock Sliders use 2″ square tubing with welded gussets for added strength, with the option of a flatter step or a steeper angle for clearance. Built to handle full side support, they’re designed to protect rocker panels and doors while staying functional for everyday use.
Quick Specs:
  • 2″ square main tube with 1.75″ DOM outer rails
  • ¼″ gussets on all four legs with 3/16″ frame plates
  • Laser-cut 3/16″ steel end caps
  • Bolt-on install, no drilling
  • Hi-lift capable and built to protect rocker panels and doors
Find Them Online: https://rcimetalworks.com/product/rock-sliders-4th-gen-tacoma/
4. Westcott Designs​
Westcott Designs Rock Sliders are built from .120-inch wall tubing with laser-cut steel frame plates, hand-welded for strength and precision. They’re available in either a flat 0° setup or a 20° angle, with optional top plates that add grip and a bottle opener.
Quick Specs:
  • .120″ wall HREW or DOM tubing
  • Laser-cut .188″ steel frame plates
  • MIG or TIG welded construction
  • 0° flat or 20° angled design
  • Optional top plates with stainless accent and bottle opener
Find Them Online: https://westcottdesigns.net/product/2024-toyota-tacoma-4wd-short-bed-rock-sliders/
5. Southern Style Off-Road​
Southern Style Offroad sliders are built from laser-cut 3/16" wall square tubing and hefty 1/4" mounting plates, all powder-coated matte black with a 0° kick-out design and dimple-die top plates to help with traction even in muddy terrain.
Quick Specs:
  • 1/4" thick mounting plates
  • Laser-cut 3/16" wall square tubing
  • 0° kick-out configuration
  • Dimple-die top plates for traction
  • Grade 10.9 hardware included
Find Them Online: https://southernstyle-offroad.com/collections/tacoma-2024-up
6. CBI Off-Road​
The CBI Offroad Fab Overland Bolt-On sliders are built tough with heavy-duty DOM tubing and offer either a flat top-plate step or a sleek angled profile. They bolt up in about an hour, fit both 5' and 6' double-cab beds (excluding 2WD models)
Quick Specs:
  • Heavy-duty DOM tubing construction
  • Flat top-plate or angled options
  • Configurable for Double Cab, 5′ or 6′ bed
  • Finish choice: bare metal or black powder coat
  • Supports vehicle weight for jacking or recovery
Find Them Online: https://cbioffroadfab.com/product-category/toyota/tacoma/tacoma-rock-sliders-side-steps/
7. NyTop​
NYTOP Rock Sliders use a flat-panel design instead of traditional tube work, giving a clean low-profile look with plenty of strength. The flat top surface doubles as a step, while the angled underside helps the truck slide over obstacles without catching.
Quick Specs:
  • 3/16″ and 1/4″ high-strength steel construction
  • Flat 3″ step surface
  • 25° angled underside
  • TIG-welded design
  • Supported up to 3 metric tons during testing
Find Them Online: https://nytop.com/toyota-tacoma-accessories-store
8. Restless Off-Road​
Restless Off-Road Rock Sliders offer serious strength with 1.75″ .120 wall DOM tubing plus gussets and plates, offering adjustable protection that also serves as a functional step. These sliders come with built-in rock light brackets and versatile angled or top-plate options.
Quick Specs:
  • 1.75″ DOM round tube, .120″ wall
  • ¼″ gussets and 3/16″ mounting plates
  • Angle options: 1/8″ kick-out or full top plate add-on
  • Built-in rock-light mounting brackets
  • Uses Grade 8 hardware; bolt-on to existing frame
  • Will not fit KDSS or X-reas models
Find Them Online: https://www.restlessoffroad.com/
C4 Fab will not fit TRD Pro even tho they confirmed they would in an email. Fuel tank mount is in the way on passenger side and the d1,2,3 make the frame bolts misaligned. Plus they come with Zero instructions.
Good to know. Thanks for sharing.
C4 Fab will not fit TRD Pro even tho they confirmed they would in an email. Fuel tank mount is in the way on passenger side and the d1,2,3 make the frame bolts misaligned. Plus they come with Zero instructions.View attachment 1401
I'm really glad you posted this. I have a Trailhunter and it doesn't seem enough to say you have a 4th gen, apparently there are lots of things that don't fit the Trailhunter or TRD Pro. Annoying lol
I'm going to add one. I'm old school and was going to run one of the traditional tube and plate sliders. I decided to go in a different direction, more in the NyTop direction. I ordered the sliders from Victory 4x4. Slider protection, with the functionality of a running board. I'm sure my old carcass will appreciate them.
As a fellow old carcass careening into decrepitude, I support this. Lol
Those look nice!
For the price they should be. I decided a modern truck should have a modern looking slider. Those tube sliders are fine on my 1985. But I think after almost 40 years sliders should evolve.
Where are you from? Nothing makes us happier in America than not evolving, it's like our hallmark. Lol
Nice '85... my buddy and I got his '85 runner stuck in some snow covered rocks, LOL
Good info. I have Cali Raised on my 3G Tacoma. They're very nice and price and lead times are great. Will probably go that direction again once I have my new 4G...
I know this is an old comment but yes, totally agree, the Cali Raised sliders are great, should I ever decide to pick up a 4th gen I will be sticking with them! I am a Trail Edition kinda guy myself, would more than likely stick with that style.
Is the top-plate on the Cali Raised removable? IE, add a plate to it that is similar to C4 fab, for extra grip/traction when using as a step.
Yeah, Step Edition does have removable plates, but only on the step edition sliders. You can't add those to the Trail Edition at a later point.
Just installed my Cali Raised Trail Edition over the weekend! Super clean design and low profile. Coming from a Step Edition on my old 3G Tacoma.
Dr KDSS Pan Hard Relocation Bracket in Stock...
