Hood Struts Installed Red Line Tuning 4th Gen Tacoma
As you know the new Tacoma doesn’t have hood struts and instead has a prop rod, again…Lucking Red Line Tuning has made some gas struts work for the new 4th Gen Tacoma. They were super easy to install and didn’t require any sort of rivet like the last gen Tacoma required. They just simple attached to existing hardware and OE bolt locations. Really makes you wonder why Toyota cheaped out on such an expensive truck.
Check them out: https://bit.ly/3UbcyXa
Code: TRDJON5
Adding this to my Christmas list.
I bought a set from Amazon for less than $100. My 14YO grandson installed them for me. They were easy to install. I highly recommend these.
We’re the bolts able to go all the way through with your ditch light brackets as well?
On a level, how much MPG do you guys losing on...
First 4th gen snorkel I've seen aftermarket.
Has anyone removed the inside tailgate panel...
If you didn't know, when you lift the rear end...
So... we hit some pretty solid rock crawling a...
The 4th Gen has proven itself to be a solid...
I know fuel efficiency is always a hot topic...
Hey everyone. If you've done some deeper dives...
