AGM Battery replacement?
clovisb31
2025 TRD Off road
Hello,
I'm thinking about replacing the OE flooded lead acid battery with an equivalent size AGM type battery.
The Tacoma charging system provides 13.9 Volts to the stock OE battery.
An AGM battery typically needs 14.4-14.6 volts to properly charge.
Is the alternator/charging system voltage able to be changed/increased to allow for proper AGM charging?
Does anyone know what the procedure is? Is a dealer level Scan tool required to do this modification?
Thanks in advance.
