AUX Switch Question
Fused11
2026 Trailhunter
Does anyone make adapter plugs to avoid rewiring a new plug for the various 3rd party Aux 1-4 plugs? I realize it’s not that big a deal to cut off the OEM plug and install the aftermarket. But an adapter would be better both to speed installation and restore to stock if desired.
Need some clarification. Your truck should come with a harness or two that attaches to where those switches lead to in a couple of spots around the truck. Most people use the one under the driver's side headlight. Once you plug in the OEM harness, the other end it just a bunch of caped leads. You figure out what color is what switch/amperage, and just wire in your aftermarket electronics. You don't cut the factory harnesses or anything like that to wire something up.
Sorry it’s not the under-hood stuff. That is fine. Works great. That setup is awesome. I am replacing the stock AUX3 switch with aftermarket. The plugs don’t match.
Frankly the more annoying problem is that the steering wheel kinda blocks the view of those switches. But that isn’t fixable.
Has anyone figured out to silence the seat...
Has anyone added fog lights to a 4th Gen SR...
Hey fellas, wanted to blast a photo out to...
I wanted to start a dedicated thread for...
A couple weeks ago I installed my new...
Here are a few shots of the SXTH exhaust tip...
Tired of slinging mud and rocks down the sides...
