SXTH Element High Clearance "Trail Pipe" Exhaust Mod - Initial Thoughts
Figured this was an off-roading mod... So adding it to this section.
The factory exhaust hangs SO LOW on these new Tacomas. After all these awesome off-road ready updates, we get an exhaust that almost touches the ground... Lol. It's not that bad, but it's a bit large and hangs too low. My last truck had a trimmed exhaust, but this seemed like a quick and easy solution.
The main reason to get one is to prevent it from being demolished on the first ledge you drop off when going off-pavement. It could also flex into the bumper and scratch that as well. Pretty easy to install, just remove two bolts after the main muffler, and slide the tail pipe off two hangers, and it comes right out. Bolt on the new trail pipe with the same hardware and you're good to go. Also has a spot to connect to the factory hanger to maintain overall stability.
Tons of room gained, a way cleaner look (IMO), and well priced at $100 (as of today). Oh, and without that little extra silencer right behind the exhaust tip, there is a subtly louder rumble when driving slower and at lower RPMs. This is not an exhaust, but it does sound a touch more aggressive. Tastefully so, to my liking. 4-cylinder exhaust systems can be tough to get right, and I'm happy with this as is.
https://sxthelement.com/collections/toyota-tacoma/products/toyota-tacoma-n400-exhaust-dump-pipe
TacomaForce.com (5% Off with code "TrailSxth"):
As always, pictures below! Working on a YT video to show everything in more detail. Coming soon...
Quick shot down low.
BEFORE
AFTER
Factory part vs. Trail Pipe
Good quality.
Welds are pretty clean!
Little side profile in front of the rear wheel.
Nice! Really liking the sxth element mods! Definitely considering this one for my truck. I kind of think this should be standard on all the off-road trims...
Yeah dude, dialed brand. Got a bunch of their stuff and it's all been great. I agree on this being standard! I think someone was saying that the Trailhunter comes with a dump kit like this. I think someone ordered it on their OR trim from the factory if I remember correctly.
