4gtacoadmin
- Nov 19, 2025
- 4th Gen Tacoma
This thread covers the official fluid specifications and safety requirements for all transmission systems in the 2024+ Toyota Tacoma (4th Generation), including automatic transmission, manual transmission, transfer case, and clutch. Information compiled from Owner's Manual pages 617-618.
Critical Safety Notices from Owner's Manual:
General Fluid Capacity Notice (Page 617):
The fluid capacity is a reference quantity. If replacement is necessary, contact your Toyota dealer.
Automatic Transmission Fluid Type Warning (Page 617):
Using transmission fluid other than the above type may cause abnormal noise or vibration, or damage the transmission of your vehicle.
Transfer Case Fluid Source Requirement (Page 618):
Use Toyota approved "Toyota Genuine Transfer Gear oil LF" or an equivalent of matching quality to satisfy the above specification. Please contact your Toyota dealer for further details.
Manual Transmission Performance Note (Page 618):
Please be aware that depending on the particular characteristics of the gear oil used or the operating conditions, idle sound, shift feeling and/or fuel efficiency may be different or affected. Toyota recommends to use "TOYOTA Genuine Manual Transmission Gear Oil" to achieve optimal performance.
Capacity:
12.4 qt. (11.7 L, 10.3 Imp. qt.)
Source: Page 617
Fluid Type:
Toyota Genuine ATF WS
Source: Page 617
Technical Context:
The 8-speed automatic transmission in the 4th Gen Tacoma uses ATF WS (Automatic Transmission Fluid World-Standard). This synthetic fluid formulation is critical for optimal shift quality and transmission longevity. ATF WS has lower viscosity than previous generations, optimized for fuel economy and cold-start performance in the turbocharged engine environment. Using non-approved transmission fluid can cause shift hesitation, noise during gear changes, and potential transmission damage requiring dealer repair.
Capacity:
2.6 qt. (2.5 L, 2.2 Imp. qt.)
Source: Page 617
Gear Oil Type:
Toyota Genuine Manual Transmission Gear Oil GL-3 (GL-4) or equivalent
Source: Page 617
Recommended Viscosity:
SAE 75W-90
Source: Page 617
Technical Context:
The manual transmission uses GL-3 or GL-4 gear oil with SAE 75W-90 viscosity. This specification is critical because transmission gear oils significantly affect shift feel, idle quality, and fuel economy. Toyota Genuine gear oil is engineered specifically for the Tacoma's synchronizer system and clutch materials. Lighter or heavier weight oils, or inferior quality gear oils, will noticeably change shift characteristics and may reduce transmission life.
Factory Fill:
Source: Page 618
Capacity:
1.2 qt. (1.1 L, 1.0 Imp. qt.)
Source: Page 618
Oil Type:
Toyota Genuine Transfer gear oil LF or equivalent
Source: Page 618
SAE 75W
Source: Page 618
Technical Context:
The transfer case fluid (Toyota Genuine Transfer Gear Oil LF) is a specialized lubricant optimized for 4WD operation, including crawl control engagement and multi-terrain select modes. The "LF" designation indicates this is a newer formulation with enhanced friction characteristics for modern Toyota 4WD systems. For 2WD models, transfer case service is not required. For 4WD models, the transfer case should be serviced during maintenance intervals as specified in the Toyota Maintenance Schedule (separate document from this Owner's Manual).
Clutch Free Play Specification:
0.2 - 0.6 in. (5 - 15 mm)
Source: Page 618
Clutch Fluid Type:
FMVSS No. 116 DOT 3 or SAE J1703
Source: Page 618
Technical Context:
The clutch uses standard DOT 3 brake fluid (same as the hydraulic brake system). Free play specifications are critical for clutch engagement feel and proper operation. Clutch service is typically not required during normal operation; however, if free play exceeds specifications, dealer service is recommended.
Owner's Manual Pages:
Disclaimer:
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with technical context from Toyota EXPERT domain knowledge. Always follow your official owner's manual for warranty compliance and accurate specifications. This is a reference guide only. For fluid replacement or service, contact your Toyota dealer to ensure proper fill levels and fluid quality.
Tacoma Transmission Fluids: ATF, Manual & Transfer Case
Transmission Fluid Specifications
Automatic Transmission (8-Speed)
Capacity:
Source: Page 617
Fluid Type:
Source: Page 617
Technical Context:
Manual Transmission (with iMT Intelligent Manual Transmission)
Capacity:
Source: Page 617
Gear Oil Type:
Source: Page 617
SAE 75W-90
Source: Page 617
Technical Context:
Transfer Case (4WD Models Only)
Factory Fill:
Source: Page 618
Capacity:
Source: Page 618
Oil Type:
Source: Page 618
SAE 75W
Source: Page 618
Technical Context:
Clutch System
Source: Page 618
Clutch Fluid Type:
Source: Page 618
Technical Context:
Specification Reference Table
| System | Capacity | Fluid/Oil Type | Viscosity | Application |
| Automatic Transmission | 12.4 qt (11.7 L) | Toyota Genuine ATF WS | Synthetic | 8-Speed Automatic |
| Manual Transmission | 2.6 qt (2.5 L) | GL-3 (GL-4) or equivalent | SAE 75W-90 | Manual with iMT |
| Transfer Case | 1.2 qt (1.1 L) | Toyota Genuine LF | SAE 75W | 4WD Models Only |
| Clutch | Check to MAX line | DOT 3 Brake Fluid | Standard DOT 3 | Clutch Hydraulics |
Source Attribution
- Transmission specifications: Pages 617-618
- Automatic transmission: Page 617
- Manual transmission: Page 617
- Transfer case (4WD): Page 618
- Clutch system: Page 618
Disclaimer:
Related Information
- Owner's Manual: OM04041U (2024+ Toyota Tacoma Gas Models)
- Maintenance intervals: See separate Maintenance Schedule
- Service procedures: Contact authorized Toyota dealer
