2024+ Tacoma - Vehicle Dimensions (Length/Width/Height)
4gtacoadmin
4th Gen Tacoma
2024+ Tacoma 4th Gen Vehicle Dimensions and Capacity Specifications​
This thread consolidates official vehicle dimension and capacity specifications from pages 610-613 of the 2024+ Toyota Tacoma owner's manual, organized by cab type, drivetrain, and configuration for easy reference.
2024 Tacoma Specifications by Cab Type, Drivetrain, and Tire Configuration​
Xtra Cab Models (2WD)​
DimensionMeasurementConfiguration
Overall Length213.0 in. (5,411 mm)All tire sizes
Overall Width76.9 in. (1,954 mm)245/70R17 tires (steel or aluminum wheel)
Overall Width77.9 in. (1,980 mm)265/70R17 or 265/65R18 tires
Overall Height73.9 in. (1,878 mm)245/70R17 tires with aluminum wheel
Overall Height74.0 in. (1,878 mm)245/70R17 tires with steel wheel
Overall Height74.6 in. (1,896 mm)265/70R17 or 265/65R18 tires
Wheelbase131.9 in. (3,350 mm)All configurations
Front Tread65.6 in. (1,667 mm)245/70R17 tires
Front Tread66.0 in. (1,677 mm)265/70R17 tires
Front Tread66.8 in. (1,697 mm)265/65R18 tires
Rear Tread65.6 in. (1,668 mm)245/70R17 tires
Rear Tread66.0 in. (1,678 mm)265/70R17 tires
Rear Tread66.9 in. (1,698 mm)265/65R18 tires
Model Codes: TZNA40L-CRZSZA, TZNA41L-CRZSTA
Source: Owner's Manual Pages 610-613
Xtra Cab Models (4WD)​
Overall Width77.9 in. (1,980 mm)265/65R18 tires
Overall Height73.9 in. (1,876 mm)245/70R17 tires
Overall Height74.6 in. (1,896 mm)265/65R18 tires
Model Codes: TZNA45L-CRZSZA (TRD PreRunner), TZNA46L-CRZSTA (TRD SPORT/Limited)
Note: 265/70R17 tires are NOT available on Xtra Cab 4WD models. Only 245/70R17 and 265/65R18 tire sizes are offered for this configuration.
Double Cab Models (2WD)​
DimensionLong BedShort Bed
Overall Length226.2 in. (5,746 mm)213.0 in. (5,411 mm)
Overall Width (245/70R17)76.9 in. (1,954 mm)76.9 in. (1,954 mm)
Overall Width (265/65R18)77.9 in. (1,980 mm)77.9 in. (1,980 mm)
Overall Height (245/70R17)73.8 in. (1,875 mm)74.0 in. (1,879 mm)
Overall Height (265/65R18)74.7 in. (1,897 mm)74.7 in. (1,897 mm)
Wheelbase145.1 in. (3,685 mm)131.9 in. (3,350 mm)
Front Tread (245/70R17)65.6 in. (1,667 mm)65.6 in. (1,667 mm)
Front Tread (265/65R18, 7½J wheels)66.0 in. (1,677 mm)66.0 in. (1,677 mm)
Front Tread (265/65R18, 8J wheels)66.8 in. (1,697 mm)66.8 in. (1,697 mm)
Rear Tread (245/70R17)65.6 in. (1,668 mm)65.6 in. (1,668 mm)
Rear Tread (265/65R18, 7½J wheels)66.0 in. (1,678 mm)66.0 in. (1,678 mm)
Rear Tread (265/65R18, 8J wheels)66.9 in. (1,698 mm)66.9 in. (1,698 mm)
Note: Double Cab 2WD models are not offered with 265/70R17 tires. The wider-tire options are 265/65R18 on either 7½J or 8J wheels (different trim levels), which produce different track widths.
Model Codes: TZNA40L-PRZSZA (Long Bed), TZNA41L-PRZSTA (Short Bed)
Double Cab Models (4WD)​
Overall Width (265/70R17, 265/65R18)77.9 in. (1,980 mm)77.9 in. (1,980 mm)
Overall Height (245/70R17)73.8 in. (1,875 mm)73.9 in. (1,877 mm) / 73.7 in. (1,871 mm)
Overall Height (265/70R17)74.7 in. (1,897 mm)74.6 in. (1,894-1,895 mm)
Overall Height (265/65R18)74.5 in. (1,893 mm)74.4 in. (1,891 mm) / 74.5-74.6 in. (1,891-1,895 mm)
Model Codes: TZNA45L-PRZSZA (Long Bed), TZNA45L-PRFSZA (Short Bed), TZNA46L-PRZSTA (Short Bed)
Vehicle Capacity Weight (Occupants + Luggage)​
ConfigurationModel CodeCapacity Weight
Xtra Cab 2WD (Long)TZNA40L-CRZSZA1,060 lb. (480 kg) to 1,100 lb. (500 kg)
Xtra Cab 2WD (Short)TZNA41L-CRZSTA1,100 lb. (500 kg)
Xtra Cab 4WDTZNA45L-CRZSZA / TZNA46L-CRZSTA880 lb. (400 kg)
Double Cab 2WD (Long)TZNA40L-PRZSZA1,200 lb. (545 kg)
Double Cab 2WD (Short)TZNA41L-PRZSTA1,200 lb. (545 kg)
Double Cab 4WD (Long)TZNA45L-PRZSZA / TZNA45L-PRFSZA1,200 lb. (545 kg) to 1,270 lb. (575 kg)
Double Cab 4WD (Short)TZNA46L-PRZSTA1,200 lb. (545 kg)
Source: Owner's Manual Page 613
Seating Capacity​
Without rear seats: 2 occupants (front only)
With rear seats: 5 occupants (2 front, 3 rear)
Source Attribution​
All specifications in this thread are sourced directly from the official 2024+ Toyota Tacoma Owner's Manual:
Primary Source: Pages 610-613 (Vehicle Specifications section)
This thread presents manufacturer specifications as published. All dimension and capacity data is official Toyota specification data.
Thread synthesized from 4 owner's manual pages (610-613)
Manual content ratio: 100% (manufacturer specifications - authoritative source)
Content type: TYPE_A (Specifications - no external research required)
